• Physio-Derma Store
Physio-Derma Store
Physio-Derma Store
IS Clinical - Youth Body Serum 200ml
Store/Body care/Body Lotions, Oils & Moisturizers
SKU 01991
C$181.00
Buy more, save more
3 itemsC$168.507% off
6 itemsC$150.0017% off
This refreshing lightweight serum mist gently absorbs into the skin providing powerful hydration and antioxidant protection against environmental aggressors. The purest form of Hyaluronic Acid, potent extracts of Watermelon, Blue Microalgae, Licorice Root and Holy Herb, are combined with essential Vitamin B5 and our proprietary Extremozymes® to create a unique and effective formula designed specifically for the body. Much more than a moisturizer, this nourishing treatment leaves skin feeling fresh, soft, and more hydrated. Perfect for post-sun exposure.
BENEFITS • Hydrates, smooths, and softens • Provides potent antioxidant protection • Protects against environmental damage with Extremozymes® • Increases cellular integrity • Helps provide DNA protection • Visibly improves the signs of aging • Supports cellular health and metabolic efficiency • Paraben-free
How to use: For a refreshing boost of hydration, spray on to skin as desired.
Skin Type: All skin types. Sensitive skin . Daily protection. Sunburned skin . Dehydrated skin. Environmental protection
KEY INGREDIENTS:
Imperata Cylindrica Root Extract 1% - Rich in potassium, this optimizes and reinforces collagen synthesis and moisture absorption in the skin.
Sodium Hyaluronate (Hyaluronic Acid – Botanically Derived) 0.9% - Humectant; demonstrates hydrophilic properties – attracts and binds up to 1800 times its molecular weight in water.
Aloe Barbadensis Leaf Juice 0.9% - Anti-Inflammatory agent that promotes wound healing, collagen synthesis and contains antimicrobial properties.
Dipotassium Glycryrrhizinate (Licorice Root Extract) 0.9% - Antioxidant with anti-inflammatory, anti-irritant, and wound healing properties. Acts as depigmentation agent.
Panthenol (Vitamin B5) 0.9% - Essential element required for enzymatic functions within all cells. Enables the metabolism of carbohydrates, proteins and lipids, increasing cellular integrity and efficiency.
Citrullus Lanatus (Watermelon) Fruit Extract (Extremozyme ) 0.9% - Antioxidant and amino acid rich extract that helps to protect DNA from photo damage caused by UV-light induced free radicals.
Ergothioneine 0.9% - Antioxidant rich amino acid that helps protect mitochondria.
Eriodictyon Californicum (Holy Herb) Flower/Leaf/Stem Extract (Extremozyme ) 0.9% - Antioxidant and amino acid rich extract that helps to protect DNA from photo damage caused by UV-light induced free radicals.
Phormidium Persicinum (Blue-Micro Algae) Extract 0.9% - Antioxidant and protective properties help defend against free radicals caused by UV-light and pollutants while encouraging the cellular regeneration process.
IS Clinical - Cleansing Complex 180ml
C$72.40
IS Clinical - Moisturizing Complex 50g
C$148.00
IS Clinical - Eye Complex 15g
C$135.00
IS Clinical - Neck Perfect Complex 50g
C$165.00
IS Clinical - Lip Duo Set
C$135.00
